メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
LG G Pad 8.3 4Gは、2013年10月にVerizonから発売された8.3インチ(21 cm)のタッチスクリーンタブレットです。リアカバーの下部に黒いインクで記載されたFCC ID「ZNFVK810」でデバイスを識別できます。
Opened device looks different!
Hi,
Pried the screen off and what I see is totally different from the picture in step 2.
It appears that I am looking at the backside of the battery.
The LCD is to the right, the left side shows the back side of the battery and the frame covering the battery.
画像
画像
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
2 件のコメント
I know the black frame should be at the back of the LCD but that was the only way I could pry this thing open.
Model is LG-VK810
さんによる
I have added a pic of the back panel. It's different from the video you sent me.
さんによる
コメントを追加
1 件の回答
最も参考になった回答
@esebm totally possible but you need to know which guide you followed. Only you know where you started from. Post some pictures that show what you are looking at with your QUESTION. That way we can probably help you out further. Also, let us know what you are trying to fix. iFixitでの質問に画像を追加する方法
Update (10/31/2019)
Looks like the black frame on the left should be on the back of your LCD on the right. What is the actual model number for your tablet?
画像
このアンサーは役に立ちましたか?
スコア 1
11 件のコメント:
I followed that guide: LG G Pad 8.3 4G Battery Replacement.
When I pry the display off I don't see the pic in step 2, just the plastic frame.
There must be a way to pry off the back panel in order to get to the battery.
さんによる
It sound sto me that you got somewhere under the LCD and separated that (the LCD from the frame) one. the guide you described is the right one so that is not it. Again, pictures of what you are looking at would help us to help you.
さんによる
Yes, I did separate the LCD from the frame, that's how I interpreted step 1 in the guide. The back panel can not be removed by moving the spudger around the perimeter. The back panel on my unit is about 1/2" indented top and bottom and does not go around the perimeter.
さんによる
Any help here?
さんによる
Sure looks like you used the wrong guide. Looks like you pulled the LCD of the motherboard. Take a look at this video https://www.youtube.com/watch?v=27azAfFh... around 1:19 you see your LCD and sure looks like what you are looking at on your picture. If your LCD is still connected etc., you can always try and repair it by following the video
さんによる
6件以上のコメントを表示
コメントを追加
回答を追加する
Ed Miller さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 15
今までの合計 545
