How to deal with a water damage?
Scale got wet in the bathroom and does not start anymore.
Hi,
Do not turn on the device or try to charge it.
Next open the device and disconnect the battery from the motherboard so as to minimize any further damage.
Here are a couple of links that may be of some help.
Withings Body Cardio Teardown guide
If the corrosion on the board is bad, try cleaning with Isopropyl Alcohol 90%+ (available from electronics parts stores) and a soft brush. Also if possible do not use “rubbing alcohol” unless there is no purer IPA option available. Rubbing alcohol is usually only 70% IPA or less, can contain scents and is not as effective as purer IPA.
As always with electronics, be gentle when handling and do not brush too hard to remove the corrosion. You don’t want to remove any components from the board.
Good luck with the repair.
このアンサーは役に立ちましたか?
FYI: I had the scale does not turn after cleaning it a bit too much water problem.
Follow instructions to open scale and wiped insiders, measured voltage of 3.8v on battery, and put it back together. It still didn't turn on. After 2 weeks, I accidentally stepped on it and it turned on!
So, if it doesn't turn on, open it, dry it, put it back together and wait two weeks for moisture to dry out.
Thanks so much for the info. Our body cardio got soaked by a dripping bathing suit and then it got stuck in a loop same as Bruce’s scale. Took it apart as per tear down above. Inside was dry, but switch was damp. Cleaned it with a dry soft cloth and blew it dry with compressed air et voila! Back in business. (Had to reinstall on iPad as well). Doug
Archived tear down page: https://web.archive.org/web/201901170905...
After reading the following 2023 report comparing the accuracy and precision of 15 different home use body composition scales -- https://granttinsley.com/how-to-track-yo... -- I recommend abandoning any ailing Withings Body Cardio and getting the Omron HBF-514C (currently priced at $80 on Amazon and Walmart) to replace it. The Withings is only moderately accurate when % body fat is greater than 20%, while the far cheaper Omron is more accurate and precise than the Withings at ALL body fat ranges and therefore better tracks muscle gain and fat loss over time. Note, however, that the Omron doesn't have blue tooth, so if you want to graph your progress over time you'll have to transfer your measurements manually to a computer graphing program or graph paper.
Mine went crazy, getting stuck in a loop of continually restarting itself. I put it in the hot press for a few days after which the nature of the faults changed somewhat. It would show the weight only, then cut out. As an added bonus the info on the screen was also upside down. So it probably was water.
I reset the scale to factory settings according to Withing service instructions as follows.
Since doing this, the scale is performing normally. It now needs a new battery which is why I am on this site. Hope this helps someone.
このアンサーは役に立ちましたか?
NB: At present the link from this page to the teardown page is broken. If you can't find it, here is the correct link. Withings Body Cardio Teardown
The link to the teardown page in the Most Helpful Answer above, works when I click on it
If none of the above work, the components inside your reset button on the side of the unit are probably too corroded. You’ll need a replacement part, which Withings won’t send you. This is a basic design error that Withings are ignoring. This is the 2nd product I’ve had design issues with. Take from that what you will but this user will never be buying from them again.
このアンサーは役に立ちましたか?
I had a similar issue with my withings body cardio (reset loop) - I disconnected the USB / button plate, cleaned it - helped a bit, but still ocassionally it would reset. So I disconnected it permanently, will connect it back again when the scale needs charging. Works for now.
Next time I will check which of the wires is responsible for the switch and will disconnect just that one - that should keep charging capabilities.
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 11
過去 30 日: 70
今までの合計 8,559
2 件のコメント
My cleaning lady also damaged the scale with water, just one week after buying it. Really frustrated. Particularly for such expensive product, it should be better designed.
The interior looks good, so I guess is just the side button which was exposed to water
Miguel Duarte さんによる
My scale also had a water accident last week.
I took it apart using a video I saw on YouTube and upon inspection there were no signs of corrosion, but the battery was empty, showing only 0.7V.
I put it charge and the voltage started to increase. I left it charge for a few hours and at some point when it reached about 3.8V I pressed the button on the tiny card.
The display turned on and it was showing the charging icon and 0%, which is a sign that it's working and just needed to be charged more.
I let it charge for a few more hours until it reached about 4.3V, when the battery is fully charged, and the battery seems to hold charge.
But now it's not turning on anymore, seems as if the board entered some broken state and no longer booting up.
Tried to reset it by long pressing the button, and also cut and later re-connected the red battery wire thinking it might help hard reset the board, to no avail.
I have no idea what else to do with this. Any suggestions would be really appreciated!
Cristian Măgherușan-Stanciu さんによる
