メインコンテンツにスキップ
必要な工具と部品
この分解は修理ガイドでは ありません。 お持ちのWithings Body Cardioを修理する際は、iFixitの修理ガイドをご利用ください。
  1. Withings Body Cardio Teardown, Opening the scale: 手順 1、 3の画像 1 Withings Body Cardio Teardown, Opening the scale: 手順 1、 3の画像 2 Withings Body Cardio Teardown, Opening the scale: 手順 1、 3の画像 3
    • Opening up the scale was not an easy task – there was a lot of double-sided tape involved.
    • The back of the scale is fastened with four Torx screws – easy enough. The entire backplate, however, is glued to the front with double-sided adhesive cushions. Removing it simply involved pulling it firmly enough to break the adhesive, but not so hard as to break the connectors. A hairdryer can help loosen the adhesive under the 4 corners.
    • With the backplate removed, you can immediately spot 4 loads cells, one in each corner.
  2. Withings Body Cardio Teardown, Main PCB: 手順 2、 3の画像 1 Withings Body Cardio Teardown, Main PCB: 手順 2、 3の画像 2 Withings Body Cardio Teardown, Main PCB: 手順 2、 3の画像 3
    • ARM MCU - MK22FN1M0VLL12 (NXP)
    • weighing scale and body composition front-end IC - AFE4300 (Texas Instruments)
    • battery charging IC (including battery protection) - BQ24095 (Texas Instruments)
    • WiFi and Bluetooth radio - BCM43438 (Broadcom)
    • flash memory - MX25L3233F (Macronix)
    • op-amp - AD8544
    • connector to the USB port PCB
  3. Withings Body Cardio Teardown, Block diagram: 手順 3、 1の画像 1
    • I’ve made an attempt to design a block diagram for the whole setup. This won’t be 100% accurate as I don’t know all the details but it will give you an idea on how the components are interlinked and work together.
作成者
3人の作成者と共同で作成されました。
November Five
メンバー登録日: 08/25/16
465 ポイント
4のガイドは作成済み
38 件のコメント
Thanks for sharing your experience, wouldn’t guess the double sided tape trick without your help.
Soon my scale will be deactivated by Nokia and was wondering what I can do with it.
ALMO - 返信
Hi please tell me what are battery dimensions. I need to order one - cause mine is already dead.
Michal - 返信
Hi, I never took note of the dimensions, it’s best you open up the scale yourself to check it out.
Since the battery is dead you’ll have to do it anyways ;)
November Five -
Thanks for the breakdown info. I'm replacing the battery as well. It's 63x50x5mm. 2100 mAh, 7.98Wh, 3.8V
I think this battery should be exactly the same:
Samsung 2100 mAh Replacement Battery for Samsung Galaxy Avant SM-G386T https://www.amazon.com/dp/B00OY9BY6W/ref...
Ryan Wills - 返信
Hi,
my battery died as well. Was the Samsung battery the correct replacement?
With best regards
MArtin
spamfilter -
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 39
過去 30 日: 186
今までの合計 24,096
