メインコンテンツにスキップ
The TI-30X IIS is a scientific calculator with trigonometric functions first introduced by Texas Instruments in 1993. It uses both a battery and a solar cell for power.
7回答 すべてを表示
The LCD readout symbols are fading. Is there an easy fix.
I have several TI-30X iis calculators I use in my classroom and the LCD readouts are fading. Is there an easy fix or are they shot?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Your calculators might be having a similar issue to the TI-84 Plus calculators where the ribbon cable is degrading. If you have soldering experience, then you might want to take a look at this guide here: Texas Instruments TI-30X IIS Battery Replacement for instructions on how to take apart the calculator. Refer to this topic on Cemetech for instructions on how to fix a ribbon cable: https://www.cemetech.net/forum/viewtopic...
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
sounds like a lot of work for a non -techy
さんによる
If you don't want to try fixing the ribbon cable, then you can try Duane's suggestion of replacing the battery and adjusting the contrast. Although I find it unlikely that's the issue, hopefully it is something as simple as that. Otherwise you'll have to find a friend or student that's willing to take on such a project, buy a whole new calculator, or just deal with a partially broken screen.
さんによる
コメントを追加
Sounds like the Contrast setting is lowering, how are the batteries also?
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Poor description on my part. You can see some numbers or parts of numbers.
さんによる
I stick with my suggestion of adjusting contrast, otherwise, time to replace the unit.
さんによる
コメントを追加
回答を追加する
Doug Dahms さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 42
今までの合計 1,183
