メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2019年9月20日に発売されたAppleのメインストリームiPhone 11は、6.1インチのLCDタッチスクリーン、デュアルカメラを搭載し、6色展開です。iPhone XRの後継機にあたります。
Screen replacement compatible with XR?
My iPhone 11 screen has cracked and I cant find an 11 lcd screen replacement to buy anywhere online to repair myself. After some looking for picture of both the XR and the 11 under the display and the screens itself they look very very similar. Could I possibly buy an XR display and use it on the 11 with it fitting properly?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 4
1件のコメント
XR is not Compatible with 11
さんによる 共有
コメントを追加
3件の回答
ベストアンサー
The display modules look the same, but you can’t install the screen from iPhone XR to iPhone 11 because they have technical incompatibilities.
このアンサーは役に立ちましたか?
スコア 5
コメントを追加
No. They may look the same but they both have something that prevents you from using a xr screen on a 11
このアンサーは役に立ちましたか?
スコア 1
9 件のコメント:
https://youtu.be/AIgTrL9xbV0
you cannot interchange 11 & XR or vice versa! See video.
connectors are different.
=== Update (01/02/2023) ===
After reaserching and actually trying a swap from 11 to XR I found they do not work. So no compatability.
さんによる 共有
I connected an XR screen to an iphone 11 and the display works but touch does not.
さんによる 共有
I have also plugged an iPhone XR screen onto an 11 only to find out that the touch did not work as someone else said. You can trim the excess width from the display plug and then plug in vice versa from the way the XR screen is suppose to plug in and then you realize the connectors are the same but again, as someone else here answered, technically they are different somehow bc you end up with no touch. I’ve never had any issues switching btwn series 7/7plus and 8/8plus screens tho.
さんによる 共有
I posted this long ago and recently I have found that they are different FPC connectors on the flex and and the boards, ie sizes do not match. Thanks for your reply. I do know about the 7/7+ and the 8/8+ screens and did you know the batteries also are compatible ie 6s/6s+ with 7/7+, and the 8/8+ I think the X can work for testing purposes as well, not sure cuase I have not tested that yet.
さんによる 共有
If you flip the connection around they will plug in but touch won't work. I did this about 2 weeks ago.
さんによる 共有
4件以上のコメントを表示
コメントを追加
So, the XR screen will power on on an 11. But touch may not always be consistent and could have problems. And 11 screen on an XR may power on at best, but no touch. An 11 screen may not even power on at all on an XR. So you might be able to use an iPhone XR screen on an 11, but just prepare for inconsistent touch and potential touch issues, as well as losing True Tone and Face ID.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Splityou4 さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 56
過去 30 日: 195
今までの合計 38,929
