iPhone not powering up after replacing Charging Port/3.5mm Jack Flex
I have recently replaced the following on the iPhone 6:
- Charging Port/3.5mm Jack Flex Cable
- Wi-Fi/GPS Antenna
- Home Button
- Rear/Bottom Case (Aluminium)
Everything was placed carefully but then I noticed that the Charging Port Flex FPC connector on the Logic Board has 3 damaged pins, not even sure how that happens when I gently connected everything back when I was re-assembling the iPhone.
My question is, if that would affect the iPhone to not turn on at all. I mean the connector on the Logic Board for where the Battery plugs in, every pin is good (checked with Zoom with a Phone Camera, that’s how I found out the damaged pins on the FPC connector for the Charging Port Flex cable.
The rest of the Flex cables are good, no damaged pins. Just the Charging Port Flex Cable connector (the one on the Logic Board, not the actual connector on the Flex cable) is the only one damaged.
See the attached image, all the ones in Green are good, the one damaged is the one in Red
