メインコンテンツにスキップ
2017年9月に発売されました。モデル番号はA1863、A1905。GSM もしくはCDMA/容量は64か256GB/ゴールド、シルバーとスペースグレイ
873回答 すべてを表示
very weak signal all networks
Hi,
I have a iphone 8 with very weak network signal. only picks up 1 bar and that is in and out. have tried different sims and resetting network settings , none of them have worked. only get 1 bar thats in and out on ee, vodafone etc. what part would need to be replaced? can find ones for wifi and Bluetooth but both of them work fine.
thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
3件の回答
What you’ll want to replace is the Diversity Antenna. If you’re also having issues with Wi-Fi/BT, this could resolve those issues too.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
have you ever changed the charging flex.WI-FI and bluetooth aerial is not Network antenna any more.Possible solution.
1- Antenna is connect to charging flex.
2- Bad contact of antenna to antenna connector.
このアンサーは役に立ちましたか?
スコア 0
8 件のコメント:
Thank you will check tomorrow
さんによる
I had the exact same issue. I replaced the Wi-Fi diversity antenna on my iPhone 8 (not the 8 Plus) and that didn't fix the issue. Rather replacing the top left antenna fixed my reception issue. Be super careful about the hidden screw on the side of the phone housing, it's a little bit difficult to see but as long as you have decent lighting like a lamp (like I used) then you should be able to see it. It's a little bit fiddly but not too awkward to take out the screw and put it back in but spending money on a replacement top left antenna is definitely better and way cheaper than buying a new phone. Details on how to replace your top left antenna are quite self explanatory but you can take a look on the iPhone 8 Charging Port replacement guide on iFixit:
iPhone 8 Lightningコネクタアセンブリの交換
(Step 40, 41, 42)
さんによる
update: I just realised there's also a full guide on replacing the top left antenna.
iPhone 8 Plus 左上部アンテナの交換
さんによる
I had the same issue. I replaced the down right antenna firstly and that didn't fix but top left. Thanks for sharing your experience about it Jordan Win!
さんによる
@jw25116 Thanks for this helpful comment. Can you tell me where you purchased the top left antenna? It’s not sold here
さんによる
3件以上のコメントを表示
コメントを追加
Well I will suggest you to Update your software it might help you in fixing the issue.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
dan morrill さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 10
過去 30 日: 35
今までの合計 1,742
