メインコンテンツにスキップ
モデル番号A1989、EMC 3358。現存モデルに最新プロセッサオプションとキーボード素材に変更が加えられた改良版モデル。カラーオプションはシルバー、スペースグレイ。2019年5月発売。
134回答 すべてを表示
Display got red line in some cases
Hello everyone. I have a problem with the display. When I am opening and closing the top, some red blinks appear. I attach a screenshot of this
The interesting detail is that I got repaired this Mac like a 4 days ago, the reason why I went to service center was also a problem with the display! But it was a bit different, there is also a screenshot of that
The support told to reset Reset NVRAM or PRAM with this https://support.apple.com/en-us/HT204063 instruction. For now it’s gone, but I don’t believe that it’s gone forever
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
Did they replace the display?
さんによる
Yes, really. As they told me, they replaced the whole top case of it
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Ouch! Your display has a crack! Looks like something heavy was dropped on the lid or something sat on the system.
I hope you took AppleCare+ support contract as this will cost you!
Luckily its not very hard to do MacBook Pro 13" Touch Bar 2017スクリーンの交換 We don’t currently have a direct guide for your exact system but this one will get you there.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Thank a lot, @danj! I've already replaced that display, but that's interesting to know this fact. Could you please take a look on the first screenshot? That's the case with the new display
さんによる
@birdi7 - The image is too blurry to see anything in your first image. How about trying again maybe you want to make a short vid. Use a tripod or other means to steady the camera/iPhone you might want to increase the light as well, just be careful the light is not reflected off the screen.
If this is a new display, then they may have damaged the ribbon cables that feed from the T-CON board to the LCD which is mounted within the uppercase.
The newer 2016 models moved it from the display assembly down to the uppercase which I think was a bad design decision. The number of lines is more and the flexing puts it at risk. We've already seen an issue with the backlight ribbon cable as well as overheating T-CON boards when people block the vents.
さんによる
コメントを追加
回答を追加する
Egor さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 2
過去 30 日: 4
今までの合計 576
