メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Samsung B1445Aは、Samsung製のドラム式高効率洗濯機です。
Washing machine is unblanaced
My washing was doing fine until I overloaded it. It makes a load banging noise now. I turned the drum inside and as it turns 360 it makes a clunk noise and feels like it jumps out and back in again on the turn. I hope that makes sense. It makes a loud noise when it washes and spins since i overloaded it.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
There is a filter on the drain line. If the filter is clogged, the water does not drain properly and the result is a terribly unbalanced tub. The machine will literally walk across the room. Look down low for the filter. Maybe behind the front lower panel. Or get owner’s manual to locate it.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
If not the filter, there might be a broken roller, but that is not so common. Does the tub look like it's in the proper place? Does water leak out the door? That type washer is usually capable of a big load. If the tub rollers are broken or out of place, water will leak out the door.
さんによる
I have the machine on now. I haven't put any washing in but it's still making a noise I can't explain the noise.yes water is coming out of the door
さんによる
I have the machine on now. I haven't put any washing in but it's still making a noise I can't explain the noise.yes water is coming out of the door. It definitely title sounds like the roller is out or something. Maybe even broken.
さんによる
コメントを追加
回答を追加する
Marama Davis さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 22
今までの合計 650
