A button not working
A button not workimg
If you have only just noticed some stickiness or you’ve just spilled something on your controller, you only need a minor cleaning around your buttons. Grab some Q-tips and some rubbing alcohol for this quick cleaning tutorial.
Rubbing alcohol evaporates quickly and you shouldn’t be using enough to do any damage to the circuitry inside the controller. Never clean a controller with water as it can get inside and cause corrosion and circuitry damage to the controller.
Lewis
このアンサーは役に立ちましたか?
Great.. Its working!!
Thank a lot
can you mark it as an answer? Thanks.
過去 24時間: 0
過去 7 日: 6
過去 30 日: 14
今までの合計 2,027
1件のコメント
My steelseries nimbus button “B” not working
Taufiq さんによる 共有
