メインコンテンツにスキップ
2015年9月25日にAppleから発売されたiPhone 6Sの修理情報とガイドです。モデル A1688、A1633。
2690回答 すべてを表示
My iPhone 6s stays stuck on progress bar/white apple screen
Hello,
After years of not updating to the new IOS, I’ve finally decided to do so and then my iPhone 6s stays stuck with the progress bar 1cm away from its completion. I’ve kept it on all night and same result, as if it freezes every time.
I didn’t get a chance to backup all of my photos upon this occurring. I want to seek professional help and would rather pay, since I’m afraid I may mess things up.
What should I do? Is this issue repairable without my photos being lost?
Please help!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
Hello. Try to hard reset the phone by holding home and power buttons together. This may cancel the update or restart installation. If that works, backup all your photos and other data. Then you can try updating it though iTunes on a computer, or connect the phone to iTunes and restore it and you will be able to restore the backed up files and have the phone updated too. Hopefully this works.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Yes, I did exactly what you said, by force restarting it. It only takes me back to square one, it does the same thing. I also took it to my friend’s repair shop and he turned it on and connected it to iTunes, it never loaded and stayed stuck on the progress bar.
Thanks
さんによる
You could restore it with iTunes by putting it in recovery/dfu mode but then your data is gone
さんによる
コメントを追加
最も参考になった回答
Don't do a restore just yet. Most iOS updates done through phone settings and get stuck are fixable by forcing an update through iTunes with the phone in recovery mode without losing data. Try getting your friend to force an update (retain user data) on there and not a restore that should fix this problem.
If the update fails with error -27 the phone must be restored and data can't be recovered without the use of a prior backup.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Jay Ray さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 16
今までの合計 860
