メインコンテンツにスキップ
モデルA1369、1.6、1.7または1.8 GHzプロセッサー、64、128、または256GBフラッシュドライブ
328回答 すべてを表示
Hardrive not detect and no storage
Hi
Can please assis I bought and mac book air use.
This is the message the seller send.
What.can I do screen shows and question mark
This is a used working item in good cosmetic condition that was pulled from a working environment and is guaranteed working as described. Unit powers on and posts to bios. Please note no storage or charger included. Unit failed to detect hard drive installed. For any body marks or defects this unit might have see pictures for details.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
Seems pretty self-explanatory to me. You will need to install a new drive:
MacBook Air 13" Mid 2011 SSDの交換
OWC Aura Pro SSD for MacBook Air 11" and 13" (Late 2010-Mid 2011)
Afterwards, you will need to install macOS with the following instructions: https://support.apple.com/en-us/HT204904 (use Option-⌘-R) to install via the internet.
OWC Aura Pro SSD for MacBook Air 11" and 13" (Late 2010-Mid 2011)の画像
製品
$45.99
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
great links thanks
さんによる
コメントを追加
Is this the message the seller advertised the unit
“This is a used working item in good cosmetic condition that was pulled from a working environment and is guaranteed working as described. Unit powers on and posts to bios. Please note no storage or charger included. Unit failed to detect hard drive installed. For any body marks or defects this unit might have see pictures for details. “
If so he telling you that it came with no hard drive
So it bound to give you a message like
Hardrive not detect and no storage”
storage (Data) is stored on a Hard Drive
このアンサーは役に立ちましたか?
スコア 0
4 件のコメント:
Thanks Jerry I still await the unit I let you no when it arrive this is the serial number C02GTTNQDJWT can you assist with the model
さんによる
Every Mac has a specific serial number that is required for the many benefits that Apple offers to its customers, including warranty service. Most people won’t require the need of the serial number throughout their Mac’s life cycle, but you may need to occasionally look it up.
So you be looking for the model number of the unit to get parts for it
さんによる
Yes I need to no what model is it eg 2011 or 2010 or so to see what hardrive and charger I need to buy
さんによる
correct Mark
さんによる
コメントを追加
回答を追加する
Mark Petersen さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 7
今までの合計 74
