Horizontal line on top of the display
Whenever i turn my laptop on, after using for 15-20mins/ half an hour the horizontal line on the top of the display showed itself, and vibrate continuously. It get bigger in width slowly.
if i put it to sleep for 5mins and open again, everything look likes okey. but after around 15mins again that line blow up
help me if there is any solution. isn’t there any solution without replacing display?
i have no warrenty left from apple
Macbook Pro 13” 2017
12 件のコメント
Here's someone else facing the same problem Horizon blur black line on top of MacBook Pro 2017
DanJ さんによる
do you know about the reason behind this kind of damages?
Arif Amzad さんによる
The cause is over-heating. Blocking the vents by using the system on a bed or other cloth surface which the system sinks into. Heavy online gaming which is very heavy with graphics. And lastly, heavy image or video editing.
I've had to replace over ten displays across the entire line. We have over 20 posts here alone of people encountering this issue.
DanJ さんによる
How can it be over heading when an external montor works on it with no lines
edigitcom さんによる
The T-CON board is part of the internal display it has no involvement with the external display ability to display.
If I break (crack) the internal display screen that won't impact the external display will it. You are trying to rationalize displays A issues as impacting display B you just can't here.
DanJ さんによる
7件以上のコメントを表示
