メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
ChryslerのJeep部門が製造した高級ミッドサイズSUV、初代Grand Cherokee ZJの修理ガイドとサポート情報。
Stalling and not starting intermittently
I have a 95 Jeep Grand Cherokee that has less than 100k miles on it. So it’s in great shape for its age. The problem is that it has started to stall when driving it - it stalls when it is decelerating. It only does it every once in awhile. Also, it usually starts right back up but sometimes it will not. If I keep trying it will eventually restart.
My regular mechanic can’t figure out the exact problem so I was wondering if anyone out there has a clue. Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
Its a long shot , but I had the same symptoms with a Chev. half ton. After a lot of run around. It turned out to be the gear on the rear of the Camshaft. Pricey to fix , traded up to a ram!!!  Good Luck.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Sounds like what our 96 GC 5.2l was doing when we had a bad battery. Lots of feathering the gas pedal while braking/stopping. And holding RPMs while stopped & in gear. Try a known good battery.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Annette Givens さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 36
今までの合計 423
