メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2018年8月に発売された、スタイラスペン付属のSamsungのフラッグシップスマートフォンで、Note8の後継モデル。6.4インチのディスプレイを搭載し、最大512 GBのストレージを備えています。
Wrong file TWRP bootloop
Hi,
After install TWRP from Odin my Note 9 was stay on bootlop 'Samsung Logo' and restarting, i can't go to Download Mode and Recovery but phone only restarting bootloop.
It happend after install wrong twrp files (\twrp-3.3.1-1-star2qltechn.img.tar) i have select on Odin "Rebooting"
What's going now? Regards Thank you for help
Recovery and Download doesn't work, i can't going to him.... only restarting *****
video: https://streamable.com/k242c
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント
Hi Eda Ea, did you able to fix the problem , I faced the same one
さんによる 共有
Hi eda ea
i have the same problem
were you able yo fix your phone?
if yes, could you please tell us how?
thank you
さんによる 共有
コメントを追加
3件の回答
最も参考になった回答
Turn it off full power off take cable out hold volume and Bixby whilst holding plug in USB
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
After a failed attempt to remove the battery and ending up cracking the back glass, what you said was the solution. Just ONLY hold volume up and bixby, then plug in the USB. Thank you very much!
さんによる 共有
i cain't turn off my phone it just go off and on on logo after it's off i plug it in and it starts again. holding buttons doesnt help
さんによる 共有
コメントを追加
Hi Eda ea !
There is always a risk when ROOT a smartphone.
Did you try the recovery mode with the following commands :
Volume Up + Bixby + Power key together for a few moments
画像
このアンサーは役に立ちましたか?
スコア 0
4 件のコメント:
I waiting for battery runs out of charge.  And push Volume UP + Bixby + Connect Cable USB, was starting to Samsung logo and bootloop…. i installed TWRP from other model (A6+) my misstake… and have select option in odin Nand Erase and Auto Rebooting…
さんによる 共有
Indeed, if the wrong TWRP model has been installed.
A reset factory will have to be done.
I suggest you consult this link: https://www.hardreset.info/devices/samsu...
さんによる 共有
Not possible it’s same problem….
さんによる 共有
If even this procedure does not work, I am afraid there is no other solution, unfortunately. Maybe another member will have a second solution.
Good luck with that!
さんによる 共有
コメントを追加
please help me i have the same problem
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
eda ea さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 30
今までの合計 1,526
