メインコンテンツにスキップ
1.86GHzもしくは2.13GHzプロセッサ、フラッシュストーレッジは128GB もしくは256GB
146回答 すべてを表示
Broken keyboard on the new MacBook Air 13 due to water
I spilled some coffee accidentally on the keyboard, and now 10 keys dont work on the left side of the keyboard, all the other keys work, but its hard to not be able to press all the letters.
Is there a way to replace this keyboard? Where can I buy the part online?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
5件の回答
ベストアンサー
I think your best bet is to follow the guide to remove the top case. It appears to me that the procedure exposes the back of the keyboard and should allow cleaning to possibly restore full function to your keyboard. While you have it apart please do a complete cleaning of all the parts of the computer. Be advised the author of the guide list this procedure as VERY DIFFICULT. If cleaning fails you may need to replace the top case. Good luck.
MacBook Air 13インチ Late 2010の上部ケースの交換
Electronics Water Damage
このアンサーは役に立ちましたか?
スコア 4
6 件のコメント:
Hi rj713, I was wondering if I can send you a new top case and my MBA, if you could perform the repair for a fee? Thanks
さんによる
Hi, I'm not set up to do the quality work you require. If you want to talk to a working tech I would suggest you contact either mayer or rdklinc. You will find their email data on by clicking on their avatar. Good luck.
さんによる
+ Thanks rj, I'd be glad to handle it.
さんによる
Hi Mayer, I sent an email to you a few days ago did you get it?
さんによる
I'm not sure, are you Larry?
さんによる
1以上のコメントを表示
コメントを追加
最も参考になった回答
Here's the guide for doing this yourself: MacBook Air 13インチ Late 2010の上部ケースの交換
It is pretty involved. Are you sure that's all that's wrong with it. iFixit doesn't actually do repairs, they just show you how. But there are some professionals who contribute answers for them. They are not affiliated with iFixit. You can go to Users to find one. Click on their icons to see if they are pros and where they are located. I'm one such person and others may make a post who might be willing to do this for you. You can then email them if you find one you like.
UPDATE 8/25/11
You now hold my record for the farthest away repair I've worked on. Shanghai to Lubbock, TX is quite a distance. I just got in the new Pentalobe screwdrivers from iFixit to do the repair. Do I need to order your part or will you have it shipped to me.
このアンサーは役に立ちましたか?
スコア 5
2 件のコメント:
Excellent decision to sent it to you all the way from Singapore. Your reputation precedes you ......:-)
さんによる
I guess I did it right, it didn't come back and the PayPal went through. It did cost about $55.00 to FedEx one way.
さんによる
コメントを追加
To check out if anything else was damaged please hook it up to an external keyboard.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
この回答は他の質問に帰属しています。
I had this problem (spilled some beer on a 3rd-gen MBA keyboard) and sent it to Richard Mayer (above), who did an excellent job replacing it.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thanks Sam, it was a pleasure to work with you.
さんによる
コメントを追加
I did the same stupid thing, spilled liquid into the keyboard.
Sent it to the Mac dealer for an estimate, they claimed it would be too expensive to repair, since the battery, top case with keyboard, touchpad and possibly other parts needed to be replaced.
Everything except a number of keys on the left side seems to be working 100%. When performing an Apple Hardware Test (pressing D while booting, I had to plug in a USB keyboard to do this since the D key is one of the missing ones), no errors or problems were reported!
I openend the *@$$ thing (using a non Pentalobe screwdriver so I destroyed some of the screws) and cleaned the keyboard and touchpad by running a lot of warm water through them, then let the parts dry overnight. After reassembly no improvement (but not worse either). It seems the keyboard signals pass through the touchpad, and I suspect that some of the IC's on the touchpad has been fried, so I would like to replace this, but the Apple dealer in Norway say they are not allowed to sell spare parts. Any idea where I could find this spare part ?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I got mine from www.Welovemacs.com
さんによる
コメントを追加
回答を追加する
apricotscrub さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 7
今までの合計 14,140
