メインコンテンツにスキップ
Mid 2010 Model A1278 / 2.4 もしくは 2.66 GHz Core 2 Duoプロセッサ
794回答 すべてを表示
High fans, slowness, and no battery detection
MacBook Pro 2010 will not power up unless connected to MagSafe.
Once connected, MagSafe turns green. Takes forever to start up and is extremely slow. Fans start blazing and once you get to desktop there is no battery detection.
Have tried resetting PRAM and SMC, and it has not fixed the problem.
Not sure if the SMC is actually being reset. How can I get battery detection back and stop the fans? The kernel task goes crazy taking up 90 % of system
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
It sounds like you are facing a few different issues here. The first is the battery may need replacement the second is you have a sensor which is preventing the system from working at full clocking. SMC will put the system in CPU Safe Mode when it senses a thermal or voltage problem.
Lets run diagnostics. Restart your system holding the D key do you get an error message with an error code let us know what you discover.
To check the battery install this gem of an app CoconutBattery take a snapshot of the main window and post it here for us to see iFixitでの質問に画像を追加する方法
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
i had the exact same problem. Once I ran an apple hardware test, it showed that the GPU temp sensor has failed, therefore making the fans go full speed and causing kernel panics to slow it down. Iam not sure what it has to do with the battery but replacing the logic board fixes all of the issues. you can get one here, and the guide is here
MacBook Pro 13" Unibody (Mid 2010) 2.4 GHz Logic Boardの画像
製品
$209.99
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
peruwars9 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 38
