Error code E5 is showing
I'm getting an error code E5, what does this mean and what is the solution
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi,
An E5 error code indicates a keypad failure. The usual fix is to replace the keypad, if they’re still available for your model.
What is the model number of the microwave?
If you search online for (insert full model number) parts there should be links to suppliers of parts for the microwave and hopefully the keypad will be listed.
このアンサーは役に立ちましたか?
model DQ22HS
過去 24時間: 2
過去 7 日: 10
過去 30 日: 56
今までの合計 11,524
2 件のコメント
samsung model ME6144ST
Mieczyslaw Loroch さんによる
@Mieczyslaw Loroch
Please confirm that you're getting an E5 error message on your microwave?
Not all microwave ovens use the same error messages to mean the same things.
This answer on this page was for Kenmore models and not Samsung models
Your model only has error messages 1, 2, 3, & 4
jayeff さんによる
