メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Sony XBR-65X850Dは、LEDバックライトと2160pの解像度を備えた65インチLCD Ultra HDテレビです。2016年発売。モデル番号:XBR-65X850D。
How do I remove the back panel
How do I remove the back panel? I have removed all of the screws, but along the top of the plastic cover, it seems to be clipped in. I don’t want to force it and break something. I’m trying to remove the cover that the main board is under.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
How to open back 65x 900f sony tv
さんによる
コメントを追加
5件の回答
最も参考になった回答
@corecrash yes it’s a bit tricky and here are the RIGHT instructions for it. The previous once were for the 850C
画像
画像
このアンサーは役に立ちましたか?
スコア 6
3 件のコメント:
This is not X850d!
さんによる
I am also very confused.
さんによる
@desertkiwi corrections made. Sorry the previous instructions were actually for the 850C. See if these instructions make sense to you. Good thing you commented otherwise I would have never known.
さんによる
コメントを追加
Once you have all the screws out from the back you want to wack the panel from the bottom towards the top of the tv. Essentially there are fixed screws that the back panel is resting on like a picture rests on a screw in the wall. So you want to push it up in the same plane as the tv panel. If you force the back away from the tv you will break those snaps. There are around 4 or 5 screws across the you inside the cover so it can take a lot of controlled force to knock the panel off the screws.
このアンサーは役に立ちましたか?
スコア 5
1件のコメント:
I still have difficulty to open it by this method. Do you have any video or picture instructions?
さんによる
コメントを追加
I had this problem too. Umair Khan is correct. You need to remove the screws and push the back panel upwards. It was quite hard and I didn’t want to break the panel, but it eventually worked. There are six screws at the top (pic below).
画像
画像
このアンサーは役に立ちましたか?
スコア 5
コメントを追加
Make sure all the screws are removed. You also need to remove the power cable. I’ve never worked on this TV before but a lot of them share the same features. Maybe your TV is like this version: https://youtu.be/2WtDCYjp2kg
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
remove any screws you see, including the power cord. on the bottom, by both corners there are two plastic tabs. take a screwdriver and gently pry them out. (any screws!) will prevent it from "unlocking". The tabs will slide out about 1/2". Now swing the bottom out and lift up to unhook it from the top section.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Mark さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 10
過去 30 日: 49
今までの合計 13,229
