Where to buy rubber seal for soda stream?
where i can buy rubber seal for my soda stream? I em in sous australia
I don’t own the unit so I can’t be sure of what you need. Here is a page for SodaStream replacement parts: Replacement Sealing Ring Gasket for Sodastream Nozzle Repair Accessories.
If you are hearing a hissing noise coming from your SodaStream Source, the carbonation tube is leaking gas, or the carbonation bottle is leaking, use the SodaStream Source is Leaking Gas problem page to fix the leak.
このアンサーは役に立ちましたか?
過去 24時間: 5
過去 7 日: 45
過去 30 日: 171
今までの合計 8,401
