メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Asus VivoTab Smartは、2012年11月に発売された10.1インチのカラフルなWindows 8搭載タブレットです。マルチメディアを楽しむためのIntel CPUを搭載しています。
Window installation cannot proceed
When I turn on my tablet, a message came up ‘The computer restarted unexpectedly or encountered an unexpected error. Windows installation cannot proceed. To install Windows, click “OK” to restart the computer, then restart the installation.’ I followed the instruction by clicking OK, and the message came back. I did this several times and each time the same thing happened and I could not proceed further. What should I do .
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
2件の回答
ベストアンサー
There is one thing you can maybe do. Does it have windows 10?
If yes,you can go to Microsoft’s website: https://www.microsoft.com/en-us/software...
This is the official iso(software that is designed to install the necessary operating system). You can use this software to create a flash drive installer. You must use another computer to do this though.
Once finished,
Power off the pc. Plug the flash drive into into the computer,then start the laptop while holding shift,then hit the power button and hold it until it turns off. Repeat this step until it says its checking your pc(for issues since the shift start power off step tricks it that it’s not working correctly,basically a back door to get to the next step). Then it’ll boot up into a menu for options. Click advanced,then advanced. Then click start up options with efi usb device. It I’ll then restart into the flash drive(it will use the software on the flash drive to boot),then click install on windows. This will fully install windows 10 on the laptop.
Unlike from settings when when you reset the pc,this completely deletes the operating system and recovery,and the data that allows you to reset it and reinstall.( Normally erasing and resetting only reinstalls the os. This reinstalls the os and all extra files too. It’s a true fresh install aka best of the best). This reinstalls Microsoft’s windows 10 without bloatware from your manufacturer by the way. This is actually good typically.
Let let me know if you have any further questions.
Btw you need a 16 fab flash drive or higher. 16 would work.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Thanks. I managed to get my windows back and running by following your description. Although the windows was running, the modem and touchscreen did not respond. I managed to go the ASUS support website and have utilities consisting all drivers downloaded and installed. My tablet is now working perfectly.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Hey. I’m so sorry. I forgot to mention the drivers. Usually wiring by Ethernet also updates automatically,or you can use the website as you did. Sorry. I was trying to help you out but stupidly forgot to tell you that all extra drivers need to be reinstalled.
I’m happy you got it working though :)
さんによる 共有
コメントを追加
回答を追加する
Bernard Neo さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 53
今までの合計 6,122
