メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Sony Computer Entertainmentによって製造されたPS4と通称で知られるテレビゲーム用コンソールです。2013年2月20日に製品の発表、2013年11月15日に発売されました。
Copy version 1.00 stuck
Hello, i bought a couple of ps4 games disc and all off them are not playing. Some of them stuck up saying “preparing" and for how many hours its still 0%. On the other hand, the other disc says “copy applications version 1.00”. And its stayed 0% for many hours. I check the data of each disc and its only kbs instead of gbs. I went to the store i bought the disc ,they told me its original and the problem was the ps4 system and not their disc. Additionally, i also tried finding solution on youtube. I tried restarting, updating the system, rebuilding , cleaning the disc etc, but still it doesnt work.
Im so helpless and frustrated. Thats why i look for a support group for psp users that can help me. And i really hope anyone from this website can help me.
Plssss.
Thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Blu-ray laser which reads the discs needs to be replaced. For this repair I recommend taking to a reputable console repair store to get the laser replaced.
Note that for getting this replaced e.g if you are going to do the repair make sure you always use the original blu-ray drive board that came with the PS4, any other drive boards will make the blu-ray drive non-functional.
PlayStation 4 SAA-001 Motherboard & Paired Optical Drive
PlayStation4 光学ドライブの交換
Replace a corroded, damaged, or malfunctioning motherboard and its paired optical drive. This SAA-001 motherboard and paired optical drive are compatible with a model CUH-10XXA PlayStation 4 console. Heat sinks are not included.の画像
製品
$168.99
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
I bought the ps4 for about a week now. How come it has a problem on the motherboard?
さんによる
If the PS4 is only a week old better to return it for warranty.
I've haven't run into this exact issue before and with the troubleshooting you've done software wise it's highly likely this is a hardware fault.
The last thing to do before going for warranty is option 7 linked here for re-initializing the PS4. Make sure to read the steps carefully:
https://support.playstation.com/s/articl...
さんによる
コメントを追加
回答を追加する
ghagha moy さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 20
今までの合計 4,999
