Charging Issue since 4 months
Charging with low power only, heat up. Not charging while shut down.
You likely need a new battery set the main battery is easy to replace following this guide バッテリーの取り外し You also need to replace the PRAM battery which is located under the top shield just behind the ports. Follow this guide to gain access iBook G4 12インチ 800 MHz-1.2 GHz トップシールドの交換. The battery guide has the info for the button battery.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 6
過去 30 日: 15
今までの合計 286
