メインコンテンツにスキップ
AirMac Extremeベースステーションと同時に発売されたこのハードディスクを搭載したモデルは、802.11ac対応のタイムカプセルNASです。
56回答 すべてを表示
Airport Time Capsule no longer connects to my network
My Airport Time Capsule no longer connects to my network. I was told that there is a chance the hard drive can be taken out and the data might be able to be saved to another drive. I have no idea where to start. I don’t care if the actual Time Capsule is torn apart as the TC is no longer of use to me. I downloaded your instructions on how to take it apart. Do I have to be careful as far as disconnecting the cables and power connector?
What do I need to purchase so that I can attach the TC hard drive to my MacBook?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
A 3.5” hard drive is used in the Time Capsule.
You'll need a 3.5” hard drive dock that is externally powered and provides USB connection.
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
This is the SATA to USB adapter yo are speaking about StarTech 2.5" SATA to USB adapter cable
You'll need some recovery software to pull the data off as the files structure of the drive is not MacOS compatible.
さんによる
Hmm. It's a 3.5mm hard drive installed though so the adapter won't have enough power to get the hard drive working off that adapter.
さんによる
Good point! You'll need one with a power assist (external power)
さんによる
コメントを追加
回答を追加する
Menthia Carpenter さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 7
今までの合計 120
