メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2018年10月26日発売。モデル番号:A1984、A2105、A2106、A2108。GSMまたはCDMA / eSIM、nano-SIMまたはデュアルSIMモデルあり / 64、128、または256 GB / ブラック、ホワイト、ブルー、イエロー、コーラル、またはレッド。(読み方は「iPhone 10 R」。)
How to replace : iPhone XR Rear Camera Lens Cover
Will heat release the glue of the. Lenses COVER.? I bought the lense cover but I can not find anything as to how to remove just cover by itself!?, anyone have a step by step guide or a video that you have discovered?
Thank you,
papa
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 4
1件のコメント
I used a paper plate cut a hole out the size of the rear lense and used the tip of a regular iron and kept the body of the iron away from the phone! Once it was on for about 5 seconds I used a single edge razor blade to remove small bits of glass from the ring. I immediately vacuumed any debris from the phone or the paper plate i had below the phone!
2 paper plates, iron ( no steam ) alcohol to clean camera, vacuum cleaner, jewelers glasses, white light!
さんによる
コメントを追加
4件の回答
最も参考になった回答
The glass is stuck on there really good and just heat will not help much. The glass will just keep breaking while you remove it and some will get inside. The best way to do this is by taking apart the phone and removing the camera to be able to prevent it from getting damage. You can also try using a small tip vacuum cleaner right at the camera while prying out the glass bit by bit while keeping it warm so it doesn’t end up falling in the camera.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Did anyone ever answer this? I also got a lens with cover when ordering the part.
can I remove the lens housing from the Backglass without cracking the back?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I bought a Replacement lense with the iron ring around it.. how can i replace that?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
The problem is i bought the full lens with metall ring…
さんによる
コメントを追加
I replaced the lens without taking the phone apart.
Somewhere someone recommended using a utility knife and carefully breaking the lens out piece by piece.
I did that with a utility knife and finished up with an X-acto knife. It worked fine for me.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Get Up & Go Now さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 19
今までの合計 15,096
