Tablet screen won't turn on
my tablet dropped from the top of my brothers bunk bed onto a wood floor and now the screen is black, I still hear notifications and alarms but the screen is just dark like its turned off
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Jyuicy Guy most likely a broken display ( unlikely a dislodged cable). Use this guide Samsung Galaxy Tab E 8.0 スクリーンの交換 to open it up. It’ll allow you to check on the wiring and shows you how to replace the display.
このアンサーは役に立ちましたか?
An important thing to note is that there is a common fault on this model where it is just the display cable that gets loose from the logic board and needs to be reseated, additionally with tape added to stop it from getting loose again.
More explanation please.
I have one.
And the backlight is off.
There's a common problem where the screen cable gets loose from the tablet's logic board and it just needs to be re-seated while the battery is disconnected:
Here is a video demonstrating the problem in detail:
https://www.youtube.com/watch?v=S-w3fP5b...
To stop it from happening again you'll need to add tape to stop it from moving back or getting loose again.
このアンサーは役に立ちましたか?
Another model!
Is quite fine?
The video isn't helpful at all.
i have a samsung Tab E display coming but not continue opening only logo was displayed
過去 24時間: 0
過去 7 日: 5
過去 30 日: 28
今までの合計 862
