メインコンテンツにスキップ
モデル番号A1311 / Mid 2010 / 3.06 & 3.2 GHz Core i3もしくは3.6 GHz Core i5プロセッサ
342回答 すべてを表示
Challange to the experts: guidance in replaceing iMac HD
Here is the deal: I own an old IMAC EMC 2210, which except for some ghost stripes in the screen, works just fine for my purposes.
I have inherited an IMAC EMC 2389 from a friend with the only caveat that: HE NEEDS THE HD OF THE 2389 BACK, Safe for that part, I can keep the computer.
Question: (i) can I replace the HD on the 2389 for the HD of my 2210 (therefore, returning the HD to my friend and running the 2389 with the HD of my old 2210)? Would it work?; (ii) can I migrate hardware parts of the 2210 into the 2389 to make it work?
Greatly appreaciate the inputs from the experts.
Atualizar (07-09-2019)
Alright, so it looks like the Display Port Connector was damaged when I opened the case. As a matter of fact, it came out without me touching it.
Can I replace it?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Both are 3.5” SATA II (3.0 Gb/s) drives and are physically the same! So in its self thats not hard!
Here’s the guides you’ll need to follow:
But we do have a small issue! The EMC 2389 system uses a different arrangement for the system thermal monitoring sensor. Your EMC 2210 system uses a stuck on sensor which you can see on Step 20 unlike the EMC 2389 which uses the internal sensor within the drive its self. You’ll need this: OWC In-line Digital Thermal Sensor for iMac Late 2009 - Mid 2010 Hard Drive Upgrade.
Do consider getting a new drive instead! Your drive is quite old and may not last much longer and is likely quite small too. While you’ll still need the OWC sensor you might find getting a bigger and faster drive which are not that costly a smart move here.
As you have a SATA II (3.0 Gb/s) system you do need to make sure the drive you get is able to run at this I/O speed. Many drives today are fixed speed SATA III (6.0 Gb/s) Here’s the best drive you can get Seagate FireCuda
iMac Intel 20" EMC 2133 and 2210 Hard Driveの画像
ガイド
iMac Intel 20" EMC 2133 and 2210 Hard Drive Replacement
難易度:
中レベル
1 hour
iMac Intel 21.5" EMC 2389 ハードドライブの画像
ガイド
iMac Intel 21.5インチEMC 2389ハードドライブの交換
難易度:
中レベル
40 minutes - 2 hours
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Wow. Thanks a lot. Speaking about experts, I think you nailed it.
さんによる
@riogvs - I'm just one of many here ;-}
Don't forget to score the answer. Thanks!
さんによる
コメントを追加
回答を追加する
Guilherme さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 62
