メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
Why wont my iPhone touchscreen work after getting damp?
iphone got damp in my pocket, ive wiped it off and let it dry but now only the top half of my screen works. So i cannot type or unlock my phone, no cracks on the screen has also had a screen protector on and ive tried turning on and off. Now it will not charge but still flashes up with please charge me sign.
Thank you if you can help.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Take it to a reputable phone repair store as soon as possible for liquid damage evaluation. Do not plug it into a charger as this will cause irreparable damage to the phone if there is still liquid present on the phone’s mainboard.
The longer it is left the more severe the liquid damage gets over time (components will corrode more in the phone).
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
thank you, its turned on and is charging. Is there anything i can to make the touch work again.
さんによる
You must stop charging and shutting down immediately. If you do not bring your terminal to repair soon, it is quite possible that the terminal will stop working completely and the screen will no longer be a problem for you.
If you want to repair it yourself, you can follow the guide to repair liquid damages. Luck!
さんによる
コメントを追加
回答を追加する
Rhianon loader さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 41
