How do you replace the hard disk... is it an ssd?
Kindly send me a guide of how to replace/locate the battery even :) ..i’m used the the old hard disks
reply using mo.kanja@gmail.com if you can
Thanks.
Amos
このアンサーは役に立ちましたか?
I was asking about the Hard disk not the battery
"Kindly send me a guide of how to replace/locate the battery " was in your comment above. The second link shows a tear down of the laptop.
I am atm working on this issue, and it I’m afraid the ‘C’ drive is an SSD that is soldered on the motherboard SDINAF4-464 in my case. There are videos on YouTube that detail the steps for removal/ replacement of similar chips. However with the tools to do so and the learning curve… probably better to have done by an actual repair business. Look up ‘re-balling a chip’. two YouTubers of note; iPadrehab and Louis Rossman both.com.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 4
過去 30 日: 11
今までの合計 907
