メインコンテンツにスキップ
2012年9月12日に発表されたApple社による6番目となる iPhone。このデバイスの修理方法は前モデルと類似しており、スクリュードライバーと開封工具が必要です。GSMかCDMA方式、16/32/64 GB。 本体色は黒と白。
2522回答 すべてを表示
Was replacing battery and broke off small diode...HELP!
I was gently prying the old adhesive backed battery from my iPhone 5 and accidentally broke a small diode off the side of the 3.5mm port in the process and after installing new battery phone will not power on. Switched back to old battery which still held a charge and still can’t get it to power on so I’m guessing that little diode was important, lol. Don’t ask me how, but I was able to find that tiny diode and was able to determine exactly where it went before I broke it. See illustrated images below. What I need to know is…
a) Although obvious, is this actually the reason my phone will not power on?
b) Can this can be put back on and how would one go about doing it?
c) If not, I guess I would have to replace the whole assembly then, yes?
I realize this is an old antiquated phone but I have 64 G of memories on it that I never sync’d or backed up to iCloud (don’t trust ‘em), and I’d like to at least have an opportunity to transfer everything to a SD card. Any input on this would be greatly appreciated.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Phone powers on without charging port if battery is charged, that looks like a coil and may you have issues with signal not with powering on the phone. If you don’t have basic soldering tools is cheaper a quick getting a new Charging Port Flex Cable.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Looking better, this peace if part for Signal Antenna, and phone has to power on without that small coil.
さんによる
コメントを追加
回答を追加する
Bohdi Miller さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 2
今までの合計 91
