メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
この手頃な価格の大型スクリーンAndroidスマートフォンは、5.7インチのディスプレイと大容量の3,400 mAhバッテリーを搭載しています。
Bootlooped ZTE Zmax. Is it fixable?
So when I use this phone, the charger works only when its shut off for some reason so when I turned it off and charged it, It seemed to be full so when I powered it on, it showed “powered by android” then the metroPCS logo, then after that, it powers off then back on to the “powered by android” screen. I went into recovery and did a factory reset but that showed green vertical lines across the screen and it didn’t turn back on. I then tried to put a recovery image onto the MicroSD card but the phone just said “E:failed to mount /sdcard (no such file or directory) “. Anything else for me to try?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
Yes, Its Fixable. First, Once the screen goes black, instantly hold down volume up and down and the power button at the same time, then release power button at the “powered by android logo” and the screen should go black and there should be a red led, and that means your halfway there to getting it fixed, now just wait for the led to shut off, because that means that its fully drained to 0%. Now Plug it in to anything, and when it says battery critically low, ignore it and let it bootloop, after a few minutes it should boot up and start working again. - Love, Brayden.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I'm currently stuck in the bootloop, I'm hoping Brayden's way works. Attempting this method atm.
さんによる
コメントを追加
回答を追加する
jimmysofat6864 さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 16
今までの合計 1,003
