メインコンテンツにスキップ
2014年10月16に発表されました。モデル番号はA1347でEMC番号は2840です。
197回答 すべてを表示
Can I replace HD?
Recently, I purchased a Mac Mini 2014 A1347 model. I understand the RAM is soldered to the board and is not upgradeable. My next thought is to replace the HD and/or add a second HD.
Currently, I am running Mojave on this computer and haven’t had any problems. I was thinking of at least installing a second drive but I am not sure if I need to buy a HD tray or HD cable.
Update (05/20/2019)
If I didn’t want to replace the main HD, can I add a second drive? If so, do I buy an HD tray or HD cable?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
What is your current drive status?
Mac mini Late 2014 SSDの交換
Mac mini Late 2014のハードディスクドライブの交換
UPDATE
As you can see from the guides, adding an SSD is a 15 minute job while replacing the hard drive is a two hour job. Go here to select the size of drive to fit your needs:
OWC Aura Pro X2 SSD
OWC Aura Pro X2 SSDの画像
製品
OWC Aura Pro X2 SSD
$99.99
Mac mini Late 2014 SSDの画像
ガイド
難易度:
中レベル
15 minutes
Mac mini Late 2014 ハードディスクドライブの画像
ガイド
難易度:
中レベル
30 minutes - 2 hours
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
I am not sure what you are asking "current drive status". The computer came with the existing HD. I think it is SATA but I am not sure. The computer is working fine.
さんによる
If you have a hard drive model then you can add the blade SSD. If you add the SSD you can make it the boot drive speeding up the boot and running the apps.
Otherwise your only option is replacing the HD with a larger drive if that's what you want.
さんによる
コメントを追加
About your question. This unit is very much upgradeable when it comes to adding bigger or better hard drive. Only issue is its not as easy as just popping out a cover and pulling out the drive. To answer your exact question, this model comes with a regular mechanical drive and can be upgraded to a bigger size or even an SSD. You wont need any adapters or cables.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
I understand what you are saying. However without taking it apart, there appears to a spot below the silver plate to add a second drive. Obviously, I need an HD cable or tray to connect it to the board.
さんによる
Adding a second hard drive is not possible. You can only add a blade SSD drive.
さんによる
コメントを追加
回答を追加する
jkbmjp さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 128
