メインコンテンツにスキップ
2.2 GHz (Turbo Boost使用時最大3.4 GHz), 2.5 GHz (Turbo Boost使用時最大3.7 GHz)もしくは2.8 GHz (Turbo Boost使用時最大4.0 GHz) L3キャッシュで6 MBのクアッドコアIntel Core i7プロセッサ
774回答 すべてを表示
power adapter risk factor for burned port
hi, I have a mid 2015 macbook pro 15’’ retina my charger and macbook pro port both have pins that seems to have burned(has black circles around them) right now I can get a new charger instantly but that way i wont know if it will work and i cannot change the port quickly. will it damage the new charger pins quickly or i should get a charger and then change the port in a weeks time???
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
You haven't mentioned what kind of charger you're using, but it's quite unlikely the Mac will damage the charger whereas it's quite common it may happen the opposite, especially if you're using an aftermarket third party brick.
さんによる
コメントを追加
2件の回答
最も参考になった回答
Review this great Apple T/N Apple Portables: Troubleshooting MagSafe adapters. Make sure you’ve gotten a real Apple charger many fakes will damage your system OEM MagSafe Chargers vs Cheap Imposters: Teardown for Truth & Real vs Fake Magsafe 2 Charger Macbook Pro - YouTube
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
To be on the safe side, I would replace both of them. This would alleviate any doubt regarding the port that has the black circles on it. Just make sure your replacement charger has the correct wattage, volts, and amps needed, for this particular laptop, so it will charge properly.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Mithilesh Lokhande さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 2
今までの合計 66
