メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
モデル番号A1288/ 8, 16もしくは32 GB容量
screen not responding when I touch it
I just replace my Itouch 2nd gen screen with a new glass and bezel. i put it all back together and the button works but it won't respond to my fingers on the screen. Could the ribbon cable have moved and it's not making a good connection?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 4
コメントを追加
9件の回答
最も参考になった回答
Either it isn't connected correctly or the ribbon cable may have been damaged when you put it back together, it can tear VERY easily. This would cause the touch to stop working.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Open it back up and make sure all the cables are connected.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
It's also possible the logic board itself has a damaged port, but confirm that it's not the digitizer screen itself.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Make sure that the Digitizer ribbon is clicked in all the way, that was the problem for me.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
If the ribbon cable is plugged in good, make sure you reboot. It is about like the screens, the ipod has to reboot to see that it is connected.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Just thought of something else, the thick ribbon cable that runs up to the wifi/touch connection board could be damaged also. Changing it is very hard and this is just to reference another place to look.
さんによる
コメントを追加
try restoring the iPod touch.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
maybe the touch screen has been damaged during yout operation or there is a loose connection
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
how did you know that this was the problem with the touch screen? the "black resistor" I am having the same trouble with my touch screen. I have restored, rebooted, bought 3 different model screens, tried gorilla tape to hold down a tight connection, used 90% alcohol to clean the insides everything. Everything is working find on the ipod except I can't get the touch screen to work and it's driving me nuts!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
i figured out why the touch screen isn't working or responding, this is cause by static tiny rectangle black resistor is blown out, located on the upper pcb right between the square metal and
square plastic(like diamond)
and it is impossible to fix it ,
このアンサーは役に立ちましたか?
スコア -2
コメントを追加
回答を追加する
Al Urban さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 17
今までの合計 43,429
