ASUS X550ZA SSD Upgrade
Can you upgrade the storage from the HDD to an SSD? is there a repair guide for that? Thanks.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Yes.
https://www.youtube.com/watch?v=bbq0pYq3...
A SATA to USB external adapter will be necessary to copy the old drive to the new SSD using cloning software such as Acronis, EaseUS Todo Backup , Macrium Reflect , Clonezilla, etc.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 3
過去 30 日: 16
今までの合計 466
1件のコメント
Yes, you can upgrade the storage from the HDD to an SSD. But I think you should first ensure the Windows OS you used can be normally moved to the SSD. Otherwise, you need to install and activate the Windows operating system again. Here is a tutorial: https://medium.com/@elinawzy/move-window....
Hope it can help you!
elinaw さんによる
