メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Shark Rocket HV301は、Shark 300シリーズの掃除機の第2弾です。さまざまなアタッチメントが付属する2-in-1掃除機で、異なる床面を掃除できます。洗練された軽量なデザインにより、家庭内での取り回しが簡単です。
will nt pick up
dirt goes into the stick and gets cloged up have to take the stick and clean it and dose pick up. when i first got it i loved it. but right now it is worthless.just bought a navagater and is very hard to push.no more sharks for me.can you please tell me where i can get the rocket fixed. thank you. i live in rogersville tn.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
You may have a partial clog somewhere along the way that is keeping you from getting full suction. Try this - without the power head or rod attached turn on the vacuum, now place the palm of your hand where the rod would normally attached. Does it pull your hand towards it? If so, repeat the process by attaching the rod only. If there wasn’t good suction before attaching the rod, you likely have a clogged filter or collection chamber; try cleaning the filters with some warm water and fully empty the collection chamber. If the suction was good there, but bad after connecting the rod, then you have a clog somewhere in the rod. You might be able to fish it out or break it loose with a straightened coat hanger. If suction was good at both of those places then take a look at the hose that is at the bending point of the power head, here is where that hose will crack (this was the case for mine). A crack in the hose will lead to poor suction. Best of luck fixing the issue.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
barbara bond さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 16
今までの合計 340
