メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
A1708 / EMC 2978 — 2016年10月発売。このエントリーレベルのMacBook Proは、(OLED Touch Barではなく)従来のファンクションキーを備えています。ファンクションキー搭載モデルは、Intel Core i5プロセッサと2つのThunderbolt 3ポートを搭載しています。
Access to files on SSD drive.
Hi,
Can you please call me I’m looking for an adapter that allows me to plug in a 2016/2017 non touch bar SSD drive to either a USB-A or USB-C port to read and test drives externally.
I would need about 10 of them.
Apple Blade SSD 5GA 34+22 Pins NVMe
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
最も参考になった回答
Sorry we don't call people - To expensive!
Sadly your model uses a very different SSD connector as you can see in this MacBook Pro 13インチ Function Keys Late の分解 jump down to Step 10.
So far no one has created one. Give OWC a call to see if they have anything thats the best I can offer you.
Your only option is to get access to another Fn MacBook Pro which you can swap out the SSD to gain access to your files.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Would installing my SSD into another working mackbook pro work exactly the same? meaning i would need the apple id and password from my SSD?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I don't have 10, I had 15 made and I think I have eight left, but I would be happy to send you my PCB file, and you can send it to PCB way like I did and they can make you as many as you want, I know the design works, I've been using it for years. I designed a custom PCB adapter several years ago and had PCB Way build several of them, specifically to recover data from 38+22-MacBook Pro SSDs. They're 38+22-pin to USB 3.2 Gen2x2, so quite fast, they get the job done.
Email me.
  • Jackson
  • PhixesPhones@gmail.com
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
My above comment has the caveat of, as long as you know your password, then you're fine you can use my adapter just like any SSD to USB adapter
さんによる
コメントを追加
回答を追加する
kirk さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 12
今までの合計 2,354
