メインコンテンツにスキップ
2017年11月4日発売。モデルA1865、A1901。GSMまたはCDMA/64GBまたは256GB/シルバーまたはスペースグレイ。(発音は「iPhone 10」と同じ)。
1199回答 すべてを表示
Face id and selfie portret mode won't work
I have an iPhone X and it’s brand new (don’t asnwer with : send it to apple) it only worked 12 days and face id shows error “Face Id Is Not Avaible” and when i go to camera app and select Portrait Mode to take selfie with portrait it won’t open just get blury.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 4
コメントを追加
6件の回答
https://youtu.be/0m3uR2oFXyk
このアンサーは役に立ちましたか?
スコア 0
4 件のコメント:
If you still need help, reset Face ID, then set it up again. Go to Settings > Face ID & Passcode and tap Reset Face ID. Then tap Set up Face ID to set it up again. If you can't enroll your face, take your device to an Apple Retail Store or Apple Authorized Service Provider or contact Apple Support
さんによる
Thanks for your reply but it's not software problem it's harware. i have tried all what you can do with software but no luck
さんによる
Dis you find the solution? I have a same problem
さんによる
I have the same problem, did you find a solution for it?
さんによる
コメントを追加
i have an iphone x with face id issue and portrait mode issue with the front cam. i check your all tips it’s nothing help me. also dark mode sensor is working there is any way to fix this
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
i have same problem , and i read about it
u have 3 troubleshootings
1-first one is light sensor , make light very dark and expose it to bright dark , if screen brught it so its normal
2- second one is dark sensor , when u have call ,cover the upper part by ur hand if screen turned to black so its normal
3-third one the front camera , if its on portrait mode not blurring the back ground so its not normal.
first one and second one its repairable face id
third one ( portrait selfie camera ) not repairable one
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
All of the three not working for me it can be water damaged ? And truetone too all of the system except speaker and front camera working in normal mode , water can affect all this ? Pls need help
さんによる
コメントを追加
Face ID parts are complicated and difficult to repair. To fully understand Face ID, you can check below.
修理後にFace IDが動作しない理由
And for a detailed repair process, you need to pinpoint the faulty component first. Whether the flex cable has been ripped-off or relevant component has missing. Hope the following repair guide can help you somehow.
  1. Face ID not working caused by a broken infrared camera module flex cable: How to Fix iPhone X Face ID Not Available
  2. Face ID Not Available because of a missing component: How To Fix iPhone 11 Pro Max Face ID Not Available - Motherboard Repair
  3. Face ID Not Working After Screen Replacement - also flex cable broken: How to Fix iPhone X Face ID Not Working After Screen Replacement
iPhone Xの画像
ガイド
修理後にFace IDが動作しない理由
難易度:
中レベル
iPhone Xの画像
ガイド
ディスプレイ交換後にiPhoneXのFaceIDが機能しない問題を修正する方法
難易度:
難しい
iPhone 11 Pro Maxの画像
ガイド
iPhone 11 Pro MaxのFace IDが利用できない場合の対処法 - マザーボードリペア
難易度:
中レベル
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Not working in potrait mode
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Yes my face id is not working and I don't know why
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Adrian Zymeri さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 26
今までの合計 21,485
