メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2018年に発売されたSamsung Galaxy A7スマートフォンの2018年モデル。
Power reset or unknown upload mode
Hi, i have a problem with A750SN got stuck in bootloop. After i tried to enter download mode it shows me only “Power Reset or Unknown Upload Mode”, i have tried to connect it to Z3X and click on the “Reboot to Flash” the screen says OK but in the phone screen nothing is happening.
I will write the whole text that apears in the screen of device.
[RST_START = 0x1000000 ]
ECT : PARA002n
LPDDR4 manufacturer = Samsung
LPDDR4 Process ver = D18_B
LPDDR4 Size = 4G
LOT_ID = N0000
CHIP_ID = 0753b6b4924c
[TMU] 33, 29
asv_table_version : 2
big grp : 7
little grp : 7
g3d grp : 7
mif grp : 7
int grp : 7
fsys grp : 7
cp grp : 7
Please uncheck Auto Reset option of RDX!!
And do HARDRESET by using volume down + power key 7 secounds!!
CODE MATCHED (0)
Fatal exception in interrupt
PC is at hard_reset_hook_callback+0xdc/0x120
LR is at hard_reset_hook_callback+0xdc/0x120
I have tried the “ hardreset by using volume down + power key” but it still stuck in samsung logo.
If someone has any idea how to exit this and enter the download mode i would be very thenkfull.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Upload mode Forced upload mode with key A10
さんによる 共有
コメントを追加
5件の回答
ベストアンサー
The phone was water damaged and wouldn't recognize the USB cable.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
press power button + volum up and home button then yoU need to do factory reset data and go restart your phone and go to factory setting
and reset ur phone
さんによる 共有
コメントを追加
最も参考になった回答
after I use Z3X and click on the “Reboot to Flash” , phone will get in download mode. Then i just put the file and click on flash
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
My phone have problem video player out repair my phone
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Ok thats stupid ur phone has water damage mine has no water damage and says the same thing i just used odin on it so thats aload dog duddy im having the same problem if someone told me what the rdx was i could do it if u google rdx and android tells about cars with android fearures
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
U must press power button with volum up and home button to get in android mode and do a hardware reset and clean all ur datas then go into ur settings of phone and do factory setting and reset your phone another time then it wouldn't come
さんによる 共有
@Buisan Kahbo I've try to press power button and volum up button only cause my phone doesn't have home button, but it's still doesn't work. What should I do?
さんによる 共有
コメントを追加
حالت آپلود اجباری حالت آپلود با کلید A10 The second SIM card does not work either
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Adrian Zymeri さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 12
過去 30 日: 52
今までの合計 16,168
