メインコンテンツにスキップ
The eMac was an all-in-one G4-based Mac designed for the education market and released in April 2002. It was the last Mac to use a CRT display and was sold at a low price to schools and other institutions.
47回答 すべてを表示
No Sound Coming From Speakers
A few days ago. I played music too loud (at the max volume). It was working fine. But now, the eMac chimes but the internal speakers don’t show up in control panel. (I am running Mac OS 9.2.2, and yes it is a 700Mhz eMac, so it is compatible!) I only have Mac OS 9 installed at the moment.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
There is very little which you can fix on this system. As the sound preferences are not showing up I would try resetting the PRAM Reset NVRAM or PRAM on your Mac and given the systems age you may need to replace the PRAM battery eMac PRAM Battery Replacement
If that doesn’t work you damaged the DAC logic on your logic board. Which would need a new logic board.
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
I have a spare battery that I think would work with the system I am going to try and replace the PRAM battery.
さんによる
This is a 1/2 AA 3.6 volt lithium ion battery.
さんによる
Yes that is the battery I have I think
さんによる
コメントを追加
回答を追加する
Owen Ready さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 6
今までの合計 159
