メインコンテンツにスキップ
The Kenmore Elite HE3 is a washing machine by Kenmore.
669回答 すべてを表示
My kenmore front load washer Model #970-C 48072-00 will not start. W
kenmore front load washer Model #970-C48072-00 will not start. makes noise when start button pressed. also door will not open. lights do come on when start button pressed
Thanks
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
Linda Shimizu what kind of noise does it make? How do you load it if the door does not come open?
さんによる
I loaded the machine - closed the door - pushed start button - lights came on but only made kind of a grinding noise. I waited a few minutes - tried again - same result. At that point I tried to open the door but couldn't.
さんによる
コメントを追加
1 件の回答
ベストアンサー
Linda Shimizu  start off by unplugging your washer and leave it unplugged for a while. Then plug it back in and check if it reset. The door not opening could be an issue related to the door lock assembly Let us know what you hear/see
Update (03/30/2019)
Linda Shimizu okay so the door locked properly because your washer thought it was going to start. The grinding noise make actually come from your motor or your drive. Let me see if I can find out something more specific to your washer. It appears that this is a Canadian model number. If you have had the washer since new, there should be a tech sheet on the left hand side behind the front access panel.
Let us know if you find it.
Update (03/30/2019)
See if you can access the diagnostic mode. Also check the control lock. Press OPTIONS and SELECT at the same time until the Control (Control Lock) indicator is lighted. To unlock the controls, press OPTIONS and SELECT again.
Remove the back from your washer to see if the belt is still on
このアンサーは役に立ちましたか?
スコア 4
7 件のコメント:
I had it unplugged for an hour - just plugged it in - tried start but wouldn't start - noise sounded more like a dull buzzer and the door still wouldn't open.
さんによる
can you post some image of what you washer looks like? Use this guide iFixitでの質問に画像を追加する方法
さんによる
Thanks oldturkey03 - I'm unable to send image but will follow your instructions and keep my fingers crossed. Will let you know later if I had any luck.
さんによる
Sounds Good. Best of luck to you and keep us informed.
さんによる
pressed OPTIONS and SELECT as directed - no lights came on but on second try I was able to open the door! One problem solved! Will check the belt tomorrow and let you know.
さんによる
2件以上のコメントを表示
コメントを追加
回答を追加する
Linda Shimizu さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 15
今までの合計 1,302
