The Kenmore Elite HE3 is a washing machine by Kenmore.
637の回答 すべて表示
My kenmore front load washer Model #970-C 48072-00 will not start. W
kenmore front load washer Model #970-C48072-00 will not start. makes noise when start button pressed. also door will not open. lights do come on when start button pressed
Thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメント:
Linda Shimizu what kind of noise does it make? How do you load it if the door does not come open?
による
I loaded the machine - closed the door - pushed start button - lights came on but only made kind of a grinding noise. I waited a few minutes - tried again - same result. At that point I tried to open the door but couldn't.
による
コメントを追加
MacBook Battery 修理キット
最低価格 $69.99
Buy Now
最低価格 $69.99
Buy Now
1回答
最も参考になった回答
Linda Shimizu  start off by unplugging your washer and leave it unplugged for a while. Then plug it back in and check if it reset. The door not opening could be an issue related to the door lock assembly Let us know what you hear/see
Update (03/30/2019)
Linda Shimizu okay so the door locked properly because your washer thought it was going to start. The grinding noise make actually come from your motor or your drive. Let me see if I can find out something more specific to your washer. It appears that this is a Canadian model number. If you have had the washer since new, there should be a tech sheet on the left hand side behind the front access panel.
Let us know if you find it.
Update (03/30/2019)
See if you can access the diagnostic mode. Also check the control lock. Press OPTIONS and SELECT at the same time until the Control (Control Lock) indicator is lighted. To unlock the controls, press OPTIONS and SELECT again.
Remove the back from your washer to see if the belt is still on
この回答は役に立ちましたか?
スコア 4
コメント:
I had it unplugged for an hour - just plugged it in - tried start but wouldn't start - noise sounded more like a dull buzzer and the door still wouldn't open.
による
can you post some image of what you washer looks like? Use this guide iFixitでの質問に画像を追加する方法
による
Thanks oldturkey03 - I'm unable to send image but will follow your instructions and keep my fingers crossed. Will let you know later if I had any luck.
による
Sounds Good. Best of luck to you and keep us informed.
による
pressed OPTIONS and SELECT as directed - no lights came on but on second try I was able to open the door! One problem solved! Will check the belt tomorrow and let you know.
による
表示する 2 他のコメントを
コメントを追加
回答を追加する
Linda Shimizu さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 3
今までの合計 43
