メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
My battery is not charging
Hi,
I bought a parrot rolling spider a few years ago. Now I found it again, but while trying to charge, I realised it didn’t charge… I looked for tutorials online but nothing worked… I also tried to plug the drone in and than add the battery also with no luck…
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
Did you notice you battery getting weaker? If so this makes sense these batteries are not so grand and look for a battery replacement.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
I just ordered a new battery... Thanks for your quick response!! You are the best!
さんによる
Where did you get the battery from
さんによる
Where did you get the battery from?
さんによる
コメントを追加
How much old your battery is?
このアンサーは役に立ちましたか?
スコア 1
6 件のコメント:
I'm not sure but I just ordered a new one thanks!
さんによる
He rote in the description a few years
さんによる
Where did u get the battery from
さんによる
For srinivassai31 and others concerned; you can likely still charge an old battery. They get reluctant after sitting unused, but take it out, free of all contact, and very slow charge it for a long time. It might pump up just from that, but coaxing it along by repeating this with a little more volts each time..no more than half again its own volts, (=1½) to max at ¾ more added, will almost always get an old dead battery started again. Just watch the heat, and any swelling as signs you need to back off for awhile. Remember this is a percentage, and the smaller the battery the less added volts in a charge it can take. As example: a 12v regularly charges at 17.5v, which is half again its own volts.
さんによる
Hi, I bought the drone in 2016 and hardly used it for last few years. Now I have found that the battery has swollen. Please guide me how can I replace the battery.
Please note I am in India.
さんによる
1以上のコメントを表示
コメントを追加
回答を追加する
Maximilian Klein さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 41
今までの合計 3,261
