These lines come and go on my screen
Anyone has any idea what is this?
この質問は役に立ちましたか?
If its permanently like that, my only guess is a damaged lcd. I might be wrong though. I wouldn’t take it to Apple because they are going to tell you to get a new computer especially because yours is from 2015. Go to a 3rd party place or computer store to get a full diagnosis.
このアンサーは役に立ちましたか?
@ianshalongo - You're on the right track this is likely a bad display.
@anamiami - Lets do a few tests here to isolate the issue. What does an external display show? If it is still messed up then the logic board needs attention. If the image on the external is OK we then know the issue is within the internal displays data pathway or the display its self.
Did you drop or bang your system or sit something heavy on the lid? Did you have a liquid spill at some point or sit the system down on a wet surface?
A bang would have damaged the circuitry within the lid. A liquid spill could have damaged the display connector and its cable. The driver logic on the logic board could also be damaged.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 3
今までの合計 57
4 件のコメント
I am not sure how to connect an external monitor and it possible that it was banged, I don’t believe it was liquid but it just started out of the blue so it could have been bangued and started later
anaamaral さんによる
Thank you, although it is a 2015 I purchased brand new at apple at the end of 2017 so it is relatively new. The lines come and go
anaamaral さんによる
Hi Dan, I left the computer off for 2 days went out and purchased a new one, when I came come to transfer the information the laptop is working perfectly …Now I am super confused.
anaamaral さんによる
Now the lines are Back lol
anaamaral さんによる
