メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Mods for tiger?
Due to having just 800Mhz of processor speed, I run my iBook G4 on Tiger, 10.4.11. I realise that tiger is starting to get old so I was hoping that people might be able to recommend some safe, free mods for Tiger to spruce it up a little. Even cool open-source software suggestions welcome.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
6件の回答
ベストアンサー
Thanks for all the replies, if anyone else has this question, here is a summary of the good answers:
Super Duper, Time Machine equivalent
Firefox, Safari equivalent
Virtua Desktops, Spaces equivalent
And for lots more click here
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
最も参考になった回答
I would recommend Super Duper for backups.
http://www.shirt-pocket.com/SuperDuper/S...
It'll add functionality like Time Machine to !0.4 and to be frank thats the biggest feature missing.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Thanks!
さんによる
コメントを追加
You could switch to Firefox for your browser, as Safari probably won't be updated further for Tiger. - http://www.mozilla.com/en-US/firefox/fir...
VirtueDesktops gives you Spaces functionality - http://www.macupdate.com/info.php/id/165...
Is there anything in particular you are looking for?
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
At the moment Safari 4 runs on Tiger, thanks for the spaces one. If there is anything that adds customizability that would be great. For example I have found TinkerTool which allows you to customize things such as having the dock at the top of the screen or having an eject button in the menu bar.
さんによる
コメントを追加
you can try to do a non-native leopard installation, just put the hard drive in a mac that can install leopard, than install it, once it's done, you can put the drive in the ibook. leopard will boot regardless of the hardware, as long as it has enough ram. i did this on my 733Mhz G4, and leopard even reads the procesor speed, as 733Mhz, and it runs anyway. there are also tools that allow you to install it and bypass the specs. leopard is the last PowerPC-Compatible mac os, so there should be a lot of support for it in the future, compared to tiger.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
But I don't want it to run really slowly
さんによる
it won't run slowly, the cpu is only 67Mhz slower than the leopard recomendation, it ran fine with my 733Mhz G4, and so, there is a good chance that it will be much faster.
さんによる
Well I like Tiger
さんによる
コメントを追加
You might check out this site for software for older, slower Macs. Ralph
http://mac.oldapps.com/
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Cheers!
さんによる
コメントを追加
On the topic of non-native OS support. There is a tool out there that I remember reading about that will temporarily change the "processor speed" to make it compatible with leopard. I put that in quotes because it doesn't actually change it, but rather, it changes the cpu report in the NVRAM(? I believe), so that you may fool the Leopard OS disk into installing onto a Mac that runs slower than the 867mhz Leopard minimum. I cannot remember where I saw this tool, but I would recommend googling it and checking the Hackintosh forums.
Beyond that, max out the RAM, inquire about a HD upgrade, keep your login items to a minimum and clean the computer regularly.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
QEII Student IT さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 21
今までの合計 2,118
