Casing seal ring capresso 565
What is the correct way to reassemble the plastic ring that sits between the outside stainless steel casing and the flat plastic ring?
I can get it in the right slots but it won’t make a tight seal!
@nicole_p take a look at these guides Capresso Infinity and see if you can identify the "plastic ring that sits between the outside stainless steel casing and the flat plastic ring?" If you cannot take some pictures and post those with your question. That way we can see what you see. Right now it is hard to know what exactly you are looking for. iFixitでの質問に画像を追加する方法
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 1
過去 30 日: 6
今までの合計 182
1件のコメント
here are the pictures
Nicole さんによる
