メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
コンピュータで使用されるランダムアクセスメモリの修理ガイドとサポート情報。
RAM does not run in Dual Channel.
I have a i7 7700k, Asus Z270E and 2 sticks of Corsair LPX 8GB DDR4 2400mhz. I cannot run them in any configuration other than slots B1,B2.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
2 件のコメント
Hey, I just realized you're the same guy who posted about the USB issues. You almost certainly have a motherboard issue, it sounds like it's gradually going out, you'll probably lose more functions as time goes on. I'd recommend looking into another motherboard, or contacting Asus's warranty department.
さんによる 共有
So should I just RMA the board? I read that it all my problems are due to a bent CPU pin?
さんによる 共有
コメントを追加
2件の回答
最も参考になった回答
This sounds like a slot issue. Try taking the sticks out and blowing out the slots, then verifying you have the correct configuration your motherboard manual says. Beyond that, resetting your UEFI may help. Hope that helps!
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Hey I've tried these two steps before. There's no difference :(. I've read online that it could be a bent CPU pin but I'm not sure on how to fix it. Thanks for trying :)
さんによる 共有
コメントを追加
This is my mobo: https://www.asus.com/Motherboards/Z87C/
This is my RAM: http://www.gskill.com/en/product/f3-2133...
Works fine in slot 1-2 (Single channel) and 3-4 (Single channel), but whenever I try 1-3 or 2-4 (Dual channel), my computer won't start.
Both my RAM and mobo are capable of dual channel.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Alex Anderer さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 33
今までの合計 1,899
