メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2015年7月に発売された、iPod TouchシリーズにおけるAppleの第6世代モデル。
Battery replacement iPod touch 6 gen
Replaced a couple batteries in a couple iPod touch 6 gens. They turn on and everything works but the battery even after the replacement seems to discharge really fast and I’m not sure as to why. Could be bad batteries ? Not enough solder on the battery contacts ? Any insight would be greatly appreciated .
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
2件の回答
ベストアンサー
Bad batteries are always a possibility. Or it could be something in the iPod is drawing excessive current due to a fault. However if you are seeing this on multiple devices, poor quality batteries is the most likely reason.
It will be hard to troubleshoot without some known-good, or at least high quality parts. Personally, I like to test my “suspect” batteries with a dummy load so that I can see how much juice they can deliver.
このアンサーは役に立ちましたか?
スコア 3
4 件のコメント:
Also if it does apply. Would bad battery also be the reason why if I plug it in and indicates charging but battery percentage doesn’t go up no matter how long you leave it on charge would also be the battery itself ?
さんによる
It could also be a problem with the charging circuit on the logic board or a bad charger/Lightning cable.
さんによる
I tried three lightning cables and they all indicate charging but it just doesn’t want to charge so I’m hoping it’s a bad battery and not also the charging port cause the charging port looks like a really intense job
さんによる
Check your solder connections. Sounds like something isn’t connected correctly or possibly shorted. Was the percentage going up with the old batteries?
さんによる
コメントを追加
I replaced one today (battery from ifixit) and on first charge it only charges to 67% and don‘t go further.
Is this a normal behavior and is a part of calibration?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Barnaby Levitin さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 13
今までの合計 2,873
