メインコンテンツにスキップ
2016年3月に発売された4インチのiPhone。ハードウェア仕様は6sに類似しています。シルバー、スペースグレイ、ゴールド、ローズゴールドのカラーが揃っています。16/64 GB容量、Model A1662とA1723
1049回答 すべてを表示
iPhone SE Motherboard replacement
My iPhone SE always restart and sleep event in charging battery or play.
if i change new motherboard it will fix this issue? i already change new battery.
please help advice.
Thank very much for your advice.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
Yeah pry damage or a bad battery is usually the cause. There are usually 4 components right above battery connector and commonly one or more of them is pried off or damaged. May be hard to spot if not under a microscope.
It’ll require someone that does micro-soldering to fix this problem if this is the case.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
最も参考になった回答
Restarting can be caused by some small parts also like you cameras proximity flex charging dock, I would disconnect these and see if that helps.
Other causes could be the swi filter causing re boot every 2 minutes this is normall caused by pry damage.
Tristar failure can also be a cause.
If you decide to replace the board you could still face the same problem if the above suggestions has not been rulled out.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
@aonemob - Please don't post links to your own business in either a question, answer or comment. Please create guides with the answer with the details and again don't link to your site either. If you see someone is looking for help you can state in the response to for them to look at your ID card which you can list your business and your skills.
さんによる
コメントを追加
回答を追加する
Entertainment Media さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 3
今までの合計 171
