メインコンテンツにスキップ
2.4GHz, 2.7GHzもしくは2.8GHz クアッドコア Intel Core i7 プロセッサ (Turbo Boost 最大 3.8GHz) with 6MB 共有 L3 キャッシュ。
274回答 すべてを表示
Display goes black when diagnostic test is launched
Every time I run a diagnostic test the screen goes black either in the initial quick test or in slow or extended test. I have to force restart it to get it working again.
I know this macbook had previous water damage but it was working fairly fine.
When I connect an external display (HDMI) the laptop restarts within few minutes and keeps restarting until I disconnect the display.
I tried SMC and NVRAM reset, same issue.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Your liquid damage has continued to corrode your logic board. You’ll need to take the logic board out and do a detail inspection looking for discoloration, green or white powder (salts). All of this will need to be cleaned off and as needed replace damaged components and traces.
Here’s the guide you’ll need to follow MacBook Pro 15" Retina Display Early 2013の基板の交換 you’ll need a soft paint brush to first dust out the system and use a can of can’ed air to blow away the loose debris. Then get some cotton swabs and distilled water, don’t use tap! To wash the areas you find corrosion. Take detailed pictures of the areas you find.
You may end up finding you’ll need to just replace the logic board.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Mario Ghantous さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 30
